Author Topic: Clutch Judder  (Read 4129 times)
Offline gaz_marshall
Clutch Judder
« on: 04 June 2009, 20:51 »
Hi Guys,
I've looked at a few previous, similar sections and not sure if my problem is the same.
My clutch judders when I pull away in 1st, the revs are fine but this only starts to happen when the car has properly warmed up- starting from cold no problems. Bought the 1.8T about a month ago with 70000 on the clock and one very old previous owner- not sure if the clutch has just not been replaced and is worn or the fact it only happens when warmed up indicates some other problem? :huh:
Any help would be very much appreciated.
Gareth
Offline Steve_PD
Re: Clutch Judder
« Reply #1 on: 04 June 2009, 21:19 »
Flywheel  :undecided:
Offline Ant1981
  • Feed me, prod me
Re: Clutch Judder
« Reply #2 on: 04 June 2009, 21:23 »
Are you giving it some when you pull away or does it do this if you pull away slowly?
'09 Kawasaki Ninja ZX-6R
Offline Schuey
Re: Clutch Judder
« Reply #3 on: 04 June 2009, 21:27 »
Yep sounds like the flywheel, so the clutch should also be done as well, maybe as much as £300-£400 @ an independent???
Re: Clutch Judder
« Reply #4 on: 05 June 2009, 08:55 »
£300-400 :cry: It does it when i give it a lot of revs and if I pull away slowly, makes no difference. Is it the sort of thing that'll keep until the MOT or should I get it done straight away?
Thanks for all the advice guys
Offline barry-gti
Re: Clutch Judder
« Reply #5 on: 05 June 2009, 11:49 »
can't you upgrade to a g60 flywheel for cheaper?
Offline grahamp
Re: Clutch Judder
« Reply #6 on: 06 June 2009, 20:00 »
you can buy of ebay the a single mass  kit including the g60 fly wheel for less than £200, i payed £300.
Re: Clutch Judder
« Reply #7 on: 06 June 2009, 20:22 »
I put it in 5th at 30mph and floored it, nothing really happened, does this rule out the flywheel?
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Clutch Judder
« Reply #8 on: 06 June 2009, 20:56 »
If the revs didn't rise, that just rules out clutch slip. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
