Author Topic: Split CV gaitor with chirping & brake judder  (Read 1878 times)
Offline Mr_Orange
Re: Split CV gaitor with brake squeek / judder
« Reply #10 on: 04 June 2009, 22:14 »
The car had that corner wheel bearing replaced just before I bought it which is when I'm guessing the d.shaft damage was done.  I'm wondering now if there is an underlying problem somewhere:
What if caliper is seized (hence distorted disc)?
Is disc runout and the chirping noise associated with a poorly fitted wheel bearing?
Would anything related to these symptoms have stressed the CV joint, damaging that?
BTW Chirping noise disappears under braking, with "feedback" under braking through the car.
f u r k i t
« Last Edit: 05 June 2009, 07:52 by Mr_Orange »
Build thread clicky
Offline Mr_Orange
Re: Split CV gaitor with chirping & brake judder
« Reply #11 on: 05 June 2009, 08:57 »
Its round at the garage now.
Just shy of 2 weeks ownership and I'm hit with this!   :sad:
CV Gaitor is definitely shot - wheel is covered in grease!
If the wheel does not freely spin when raised off ground is chirping noise in motion a knackered disc or other issue such as driveshaft CV or bearing?  Would ABS affect this spinning?
Bearing was replaced 600/700 miles ago.
Any experience/knowledge/guidance appreciated!
Build thread clicky
