Author Topic: Locating boost leaks  (Read 2371 times)
Offline GregUK
  • 2001 Golf GTI 1.8T AUM 150bhp in Diamond Black
« on: 03 June 2009, 21:55 »
Am I right in thinking that it's possible to locate boost leaks using an air compressor and listening for escaping air? If so, which pipe would I be best connecting the compressor to?
Thanks :smiley:
Offline Rhyso
Re: Locating boost leaks
« Reply #1 on: 03 June 2009, 21:59 »
Thanks :smiley:
i believe most people create a plug which fits into the TIP which the air compressor then fits into and pushes air around the system
Offline GregUK
« Reply #2 on: 03 June 2009, 22:21 »
Cool, I'll give that a go. What sort of pressure should I put through the system to simulate the running pressure of a 1.8T?
Offline Steve_PD
« Reply #3 on: 03 June 2009, 22:24 »
11 bar  :lipsrsealed:
14-17 psi  :wink:
Offline Rhyso
« Reply #4 on: 03 June 2009, 22:24 »
not sure - turbo boosts at approx 8-9PSI as standard; 15-17PSI if mapped
Offline GregUK
« Reply #5 on: 03 June 2009, 22:39 »
The car hasn't been remapped (yet) :smiley:
I'm getting code 17705 along with the symptoms to go with it. I've checked all of the hoses and can't see anything obvious, but I'm convinced there is a leak. I'm guessing I'll see the pressure drop before it reaches 8-9 PSI.
Offline T_J_G
« Reply #6 on: 04 June 2009, 09:00 »
Could be the one in the wheel arch?
Offline GregUK
« Reply #7 on: 04 June 2009, 09:35 »
The pancake pipe? I couldn't see any damaged hoses or anything, but I suppose the joint could be leaking.
Offline dubcruiser
  • Audi A3 SB S-Line 2.0T Quattro 2007
« Reply #8 on: 04 June 2009, 09:59 »
Would check this, in fact take it apart and clean up the joint. Mine was leaking there, as it had oil residue that had ran from the leak down the pipe. Remade the joint and the BOOST is back!!  :wink:
Scott
Golf GTi 180bhp 6 Speed 2003, Tornado Red, Electric Sunroof, Climatronic, Winter Pack, Black Leather, Santa Monica Alloys, Centre Arm Rest, 6 Disc Changer, R-Tech Remap (Now Sold)
Audi A3 Sportback S-Line 2.0T Quattro 2007, Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, Auto Lights, Auto Wipers, iPod Prep, Interior Light Pack
Offline GregUK
« Reply #9 on: 04 June 2009, 10:08 »
Excellent! Will check this first then as it sounds like a common weak spot.
