Author Topic: HOT WEATHER - car wont start (no noises at all)  (Read 1041 times)
Offline whit
« on: 02 June 2009, 18:14 »
i've spotted a pattern to my non starting problem.
it seems to do it when the weather is hot, when the car has been in the sun for hours.
when i say none start i mean nothing at all no cranking, solenoid clicking etc.
i'm pretty certain it's the ignition switch or something similar.
would it make sense that the hot weather/strong sunshine (hence very hot cabin temp) is causing some metal connection/wire to expand and therefore loose electrical connection????
anyone have experience of this sort of phenomenon???
thanks people
Offline Mikester
  • Civic Type R
Re: HOT WEATHER - car wont start (no noises at all)
« Reply #1 on: 02 June 2009, 18:20 »
Ignition switch is a likely cause, but the heat shouldnt have anything to do with it.
Mine went in the winter.  lol :)
« Reply #2 on: 03 June 2009, 08:28 »
try jumping the starter motor red/black wire pin with 12v from the battery the next time it happens, use a chunky wire tho. if starter turns then its a wiring or ign switch fault, if it doesnt its the starter.  Some mk3s have an alarm module i believe? if so it could be that breaking down in the heat?
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #3 on: 03 June 2009, 17:09 »
Just as a thought, try "lifting" the key when you turn it - I had this problem. I changed the key switch, but it did it again after a while so I got my auto-electrician friend to bypass it and fit a starter button. Works fine now - key to poistion 2, press button.  :cool:
Keeping schtum. Mostly.
Offline Khare
  • The bear that khares
« Reply #4 on: 03 June 2009, 17:13 »
I had this problem in my mk2. It was the cnnector on the back of the ignition switch was loose, so I just plugged it in properly and all was well.
