Author Topic: Rear washer jet  (Read 5572 times)
DrewiD
Rear washer jet
« on: 02 June 2009, 17:07 »
Hi all, it seams my rear wiper wash jet is blocked.Ive been told i can clean it out with a pin or nidel.Ive tryed this but no luck.Any tricks or tips on how to do this properly?   Thx
DrewiD
Offline Dubbz
Re: Rear washer jet
« Reply #1 on: 02 June 2009, 17:30 »
Have a search on here for rear washer pipe.  :shocked:
you may find the roof lining is wet or and the boot floor is wet.
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline Stronz
  • Sold!
Re: Rear washer jet
« Reply #2 on: 02 June 2009, 17:31 »
Make sure its not leaking into your boot, rather than blocked. Its quite common for the washer line to become blocked then detache itself. There are two common places for the washer line to detach:
1) Right behind the motor on the boot lid (often causes it to drip onto the micro switch and tell the car the boot isn't shut - also makes the alarm go off)
2) On the left hand side rear quarter panel by the headlining- there is a 90 degree plastic bend with two pipes connecting onto it. if this has become detached, there will be a collection of washer fluid in your boots cubby hole were the first aid kit is. Especially if you continue to try and use it in an attemtpt to remove the suspected blockage!!!
Do a search for rear washer jets - I posted a thread with the problem and directions on how I fixed it at the begining of the year. Let me know if you cant find it!
Offline Dubbz
Re: Rear washer jet
« Reply #3 on: 02 June 2009, 17:36 »
:nerd: what he said. :afro:
Offline Stronz
  • Sold!
Re: Rear washer jet
« Reply #4 on: 02 June 2009, 19:02 »
Well I dont have a mechanical mind at all, so problems under the bonnet I'm useless at (although I just managed to diagnose faulty coil packs without Vagcom!).
But when a simple problem like this pops up which I have already dealt with thanks to this forum, I'm striaght in there to look a little knowledgeable!!!
DrewiD
Re: Rear washer jet
« Reply #5 on: 02 June 2009, 20:51 »
i didi a search for wash jets,,, thx, but there is no leak in the boot so it does seam to be a blocked jet. Any serjestions how to unblock it?
Offline alex160
Re: Rear washer jet
« Reply #6 on: 02 June 2009, 21:37 »
you can buy washer jet tools, or just use a piece of wire off of a wire brush and poke that down it a few times, should clear it.
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
DrewiD
Re: Rear washer jet
« Reply #7 on: 02 June 2009, 22:59 »
thx m8  i'll try that 2moz
Offline jtomlin
  • 1999 AGU 1.8T GTI
Re: Rear washer jet
« Reply #8 on: 03 June 2009, 00:05 »
i did the pokey thing earlier on after reading this, and it just shoots out a jet of water, if i quickly do it, i can shoot people passing by on the right before the arm swishes round, is this right? or is it supposed to be an even spray like the front?
Offline GIJo
Re: Rear washer jet
« Reply #9 on: 03 June 2009, 10:47 »
Do you mean that when the washer arm moves, the water moves with it?
If so, your motor might be on the way out. Mine was like that when I bought my car and I thought it was a design fault for ages until it stopped working completely. New one from breakers for about £30 sorted it!!
