Author Topic: timing belt screaching ?  (Read 2320 times)
Offline wil0
Re: timing belt screaching ?
« Reply #10 on: 01 June 2009, 21:11 »
yeah, the roller bearings for the cams looked fine when i did the cam chain so im confused. Its strange that it only does it when i tension the belt correctly, its a new tensioner, and it did it with the old one too. it sounds like its coming from the top of the engine, but i cant be sure. i have used a special listening device (a coal chisel), but cant really find the noise. When i drive the car, i can hear it as a whine.
3Door Oak Green 91 MK2 16v GTi
Offline DOA
« Reply #11 on: 02 June 2009, 12:51 »
You dont have roller bearings for the cams and have either of you checked to see if theres any evidence of the belt rubbing on the belt cover as that sounds like the more likely problem if its not the tension or the tensioner.
