Author Topic: update, H valve fitted  (Read 3666 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 30 May 2009, 20:29 »
Guys help me, I've just been out fitting my new pollen filter and thought I'd put the N75 J back to how it should be and disaster...it broke in half!
now this leaves me with a massive dilemma, how the hell do I get to work on Monday!?!
Does anyone know if it can be bypassed as a temporary measure until I can order a new one?
Please help, I'm gonna try and glue the plastic back together but I don't see it holding very long  :sad:
« Last Edit: 03 June 2009, 18:55 by Wazzzer »
Offline james2
  • No scammers please.
Re: Urgent help needed - N75 valve....
« Reply #1 on: 30 May 2009, 20:31 »
train or a bus :grin:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 30 May 2009, 20:44 »
trains haven't run in Newport since the 1800s and there isn't a bus to where I work at 5.30, try again
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 30 May 2009, 21:42 »
put a blanking plug in, it will run without an n75 on a temp basis
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 30 May 2009, 22:03 »
yeah just wondering which pipe to block off and what ones to join together?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 30 May 2009, 22:10 »
dont blame me if it damages anything but when i did mine, i joined the 2 small ones together and blanked the Intake pipe
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 30 May 2009, 22:18 »
I may have another solution, my mate is lending me his bleed valve, gonna connect it up and wind it right in so I can at least use it. Thanks for your help, I might end up doing it that way if the valve doesn't fit  :wink:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #7 on: 30 May 2009, 22:30 »
cool hope it gets you going, i got an n75 f in my glove box bt a bit far to the isle of wight to get it to borrow
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 30 May 2009, 22:45 »
appreciate the offer, I'm ordering an H on Monday though :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 31 May 2009, 14:30 »
just connected the bleed valve up and it's running 4psi, but it runs  :cool:
