Author Topic: random top end rattle on my 16v gti ?????  (Read 1832 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: random top end rattle on my 16v gti ?????
« Reply #10 on: 02 June 2009, 21:38 »
WOAH! Piston slap does NOT mean the engine has had it    :shocked:
My 1.4 used to knock like hell!! people used to say my bottom end was about to give in any seccond... And sure enough it was just a worn piston,  I ran the car a good 20,000 miles,  slowly got louder and louder,  i got my self a doner 16v engine so i decided to rag the hell out of my 1.4, knowing it had a bad piston, trying to blow it,  after all that, when i stripped it down and inspected it, there was slight ovaling of the piston but no damage what so ever...
Modern cars do get piston slap and its something you live with,  it will cause you to loose your hearing before the piston goes pop  :grin:  Generally speaking anyway, sometimes it can scratch the bore, causes it to burn oil etc.. but the engine hasnt had it,  you can usually slap some new piston rings on or a new piston, depending on whats actually causing it.
Go out and find a ford Zetec engine that doesnt have slight piston slap when cold.. you wont find one,  never does them any harm....
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
