Author Topic: Noisy central locking!  (Read 826 times)
Offline MK3TDi1996
« on: 28 May 2009, 08:37 »
Why is it so damn noisy? Coming from the pump in the boot...
Offline Lakeside
  • wassuppp
Re: Noisy central locking!
« Reply #1 on: 28 May 2009, 10:30 »
Mine does that too, usually for about 10/20 seconds after unlocking.??
(but not every time) I have no idea about it. :huh:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 28 May 2009, 11:10 »
The pumps are noisy at the best of times, the impellers inside tend to get a bit sticky after years of use, i think it might put more strain on the motor.. hence more noise and vibration,  It should be wrapped up in foam though,  either early ones didnt have it or it gets lost because a few of mine are missing it.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline MK3TDi1996
« Reply #3 on: 28 May 2009, 14:30 »
mine is still encased in polystyrene but is a noisy bugger.
I diisconnected it and popped the cap off the have a look and see if there was anything servicable inside - not that i could see!
I put it all back together and hey presto! - it was quiet again for a whole day!  Now it's back to its usual noisy self...
