Golf mk4
Wazzzer
Bit of a problem...
Topic: Bit of a problem... (Read 1280 times)
gaz_marshall
Bit of a problem...
27 May 2009, 15:26 »
I've just fitted my new dump valve and seem to have pulled out some wires quite close to one of the hoses. The wires were attached to some sort of plug and I can't find a way to reconnect them. I just wondered if its ok to drive like this to a garage or whether I'd be silly to even turn the engine on.
I have pictures but not sure how to upload them.
Gareth
Rhyso
Global Moderator
Sir Postalot
Re: Bit of a problem...
27 May 2009, 15:30 »
www.photobucket.com
and upload
then copy and paste the 4th line under the pic into the thread
by the sounds of it you've pulled the wires out to your boost control soleniods - i wouldn't drive it if i were you
Fire Up The Quattro
gaz_marshall
27 May 2009, 15:48 »
thanks rhyso
gaz_marshall
27 May 2009, 16:51 »
are these the wires to the boost control soleniods? if so what can i do? if i cannot drive it is there a way to repair it myself- i can't really see where the wire disappears into at the other end, eek!
any help much appreciated
Rhyso
Global Moderator
Sir Postalot
27 May 2009, 16:55 »
to me that looks like your N75 valve which controls your turbo
i'm sure the petrol boys will be along to confirm
Fire Up The Quattro
gaz_marshall
27 May 2009, 19:48 »
I've had a quick look at the part no 037906240 and reckon i need a new connector, something like this?
http://www.atlanticz.ca/zclub/techtips/injectors/connectors/index.html
I could be completely wrong but it just looks like a standard connector although the one I've taken off is a sealed unit and so impossible to rewire. Could just be a case of buying a new connector and wiring it up??
Golf mk4
Wazzzer
Bit of a problem...
