Author Topic: problems starting 1.8t  (Read 5491 times)
Offline king nu2 turbo
Re: problems starting 1.8t
« Reply #10 on: 27 May 2009, 20:18 »
linz
you blew a hole in your piston, cos of the coil pack?
because i just put my car on vag com found 2 dead coil packs after some investigation. went to get a couple of replacement's but the shop only had one.
Wont beable to get another one till i go work, in the morning. got to do a 8 mile journey. Do you think that it will be alright to drive (check light is flashing)
 :cry: :cry: :cry:
Offline linz
  • vee-dub
« Reply #11 on: 27 May 2009, 20:45 »
linz
 :cry: :cry: :cry:
yes mate not good fuel leaked down an ignighted which blew a hole in the piston :( very costly
an you do no you cant just replace 2 dont you as if you do its like the other 2 will go so you need 2 replace all 4
« Reply #12 on: 27 May 2009, 20:58 »
ouch
ill av to get 3 tommorow then. How long did you leave it think ill make it 8 mile.
Do you know what compression you get at cranking check mine today got 75 80 psi max, i know this is low just want to now what it should really be (thats how i knackerd my coil packs)
Offline linz
  • vee-dub
« Reply #13 on: 27 May 2009, 21:00 »
oo i left it along time mate it sounded like a scooby it sounded tht rough lol if i had known it was coilpacks in the beginning i would of got it sorted much sooner an it wudda saved me a lot of cash an id actually have a car rite now lol
Offline danny boy
« Reply #14 on: 28 May 2009, 18:29 »
will any code reader do or is it only vagcom can find faults with the coilpacks?
Offline richw911
Offline danny boy
« Reply #16 on: 28 May 2009, 21:40 »
nice 1 rich :smiley:
Offline danny boy
« Reply #17 on: 03 June 2009, 22:06 »
done a scan with the vag code reader and got 2 codes.
 16500 engine coolant temperature circuit - range/performance problem.
 00532 transmission control module  relay-supply  voltage   (B+) malfunction low battery or bad ground.
can anyone shed any light on this as i havnt a clue. thanks
i have erased them and will do another scan in a few days time, would any of them 2 be causing  the problem ive described on 1st page?
thanks again for your help
Offline Steve_PD
« Reply #18 on: 03 June 2009, 22:26 »
  16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Possible Symptoms
    * Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
          o Diesel: an indication is extreme long time burning time of the glow indication light.
    * With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
    * With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Possible Causes
    * Wiring and/or connections faulty
    * Engine Coolant Sensor (G62) faulty
Possible Solutions
    * Check wiring and connections
    * Replace Engine Coolant Sensor (G62)
  00532 - Supply Voltage B+
00532 - Supply Voltage B+: Signal too Low
Possible Causes
    * Wiring/Connectors from/to Control Module faulty
    * Power Supply (Battery/Generator) faulty
Possible Solutions
    * Check/Repair Wiring/Connectors from/to Control Module
    * Check Power Supply (Battery/Generator)
Special Notes
    * When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
    * When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
    * Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
    * Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
 :smiley:
Offline danny boy
« Reply #19 on: 04 June 2009, 19:27 »
how long do you think i sould leave it/drive it for till i do another scan?
went out it it today for 5mins and did a scan when i got back and none of the above codes came up but this one did.
16502/P0118/000280 - Engine Coolant Temperature Sensor (G62): Signal too High
Possible Symptoms
Difficulties with starting a cold engine.
RPM at idle is irregular.
With all engine temperatures idle rpm will often vary between 900 - 1000 rpm.
Bad acceleration during warm-up.
Diesel Engines: Glow plug indicator may be on for a longer than normal time or at ambient temperatures where it shouldn't come on at all.
Possible Causes
The electrical signal coming from G62 is too low
Wiring and/or connections faulty (short circuit?)
Engine Coolant Temperature Sensor (G62) faulty
Possible Solutions
Check / Replace Engine Coolant Temperature Sensor (G62)
Special Notes
In many cars between MY 1995-2002 the G2/G62 had a bad reputation for failing often. The original G2/G62 sensor is black and the improved replacements are green.
Retrieved from "http://wiki.ross-tech.com/index.php/16502/P0118/000280"
do you think its worth getting a new temp sensor?
