Author Topic: problems starting 1.8t  (Read 5490 times)
Offline danny boy
« on: 24 May 2009, 14:00 »
its been happening for a view weeks now but this morning had to get my mate to help me bump it, it coft and jumped then started on the first attempt, when reving the engine got alot of dark smoke out of the exhaust and was misfiring when i reved it alittle, after aout 5 minutes woz ok.
any ideas as to wot  the cause could be ?
any help is is greatfull.          Danny
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: problems starting 1.8t
« Reply #1 on: 24 May 2009, 14:02 »
what engine code do you have in your Golf mate?
could be a failing coilpack or maybe something else.  engine management light come on?
Offline danny boy
« Reply #2 on: 24 May 2009, 14:05 »
no engine management light.   AGU
Offline Rhyso
« Reply #3 on: 24 May 2009, 16:03 »
stater motor?
ignition amplifier?
Offline danny boy
« Reply #4 on: 26 May 2009, 21:40 »
starter motor seems ok , the only think is that it does sumtimes makes a sort of grinding niose after the engine starts, i am goin to get it re-condisioned. or is it better to buy new?
wots the location of the ignition amplifier.
thanks for ur ideas :smiley:
Offline johnson6672
« Reply #5 on: 26 May 2009, 21:52 »
Recon/new not much difference as all the internals should be changed, try and see if you can get an exchange for a recon, it will save you time, or take it off and give it a clean then see how it is as it sounds like it is sticking abit.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline danny boy
« Reply #6 on: 26 May 2009, 22:13 »
thanks mate will need to get it done soon.
Offline linz
  • vee-dub
« Reply #7 on: 27 May 2009, 00:36 »
mine did tht it was coilpacks
i left it too long an bam there goes a whole in my piston
Offline danny boy
« Reply #8 on: 27 May 2009, 16:30 »
how wud i go about checking the coilpacks?
Offline linz
  • vee-dub
« Reply #9 on: 27 May 2009, 19:58 »
you would have to probably get them checked out unless you no what ya looking for
your lookin at like £30 a coilpack
