Author Topic: rough idle and struggling at low revs in high gear  (Read 2522 times)
Offline shepgti
Re: rough idle and struggling at low revs in high gear
« Reply #10 on: 27 May 2009, 11:04 »
Why are you driving at 1200rpm anyways? Surely all cars would. I dont drive bellow 2000rpm.
I change down at that point.
In all honesty a gti should be driven at 4k plus. lol. But thats just my opinion.
The idle speed is 900rpm, and that doesnt have enough power to move the car, hence it stalls at that speed when u lift the clutch up. So what do you expect at 1200rpm in !!!5th!!! gear!
Change down to 3rd, maybe 2nd, and put ur right foot onto the carpet. lol
have you drivin round a town doing 4k rpm in second then? :grin:
Offline Mikester
  • Civic Type R
« Reply #11 on: 27 May 2009, 11:51 »
Yes. lol.
Point is the gearbox in a gti isnt made so that u cruise around in 5th, you cruise around in 3rd. On a motorway at 70 you only use fifth for mpg wise, you could easily use 4th.
Driving a car at low revs like that is only guna cause problems.....  Dont see me making "my car dont run right" threads :P
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« Reply #12 on: 27 May 2009, 12:48 »
simple solution to this boys:)
mine was the same use to judder.:)
a nice set of new spark plugs (decent ones)
and a nice set of HT leads (once again decent ones, around £40)
this should in fairness sort it:)
if not its beyond me:)
Offline BlazinGTI
« Reply #13 on: 27 May 2009, 16:35 »
similar issue here lads, just struggles at idle. also on start up warm or cold it sometimes revs high 1600rpm ish. sometimes absolutely fine, never stalls but comes close to it.
ive done preety much everythng to resolve it but with no joy,
parts i have changed, throttle body (recon), temp sensor, crankshaft sensor, full service, all the usual relays,coilpack,dizzy, airmass sensor, bla bla bla the list goes on! to much to list! i didnt just change these bits due to the idle issue but down to poor running. had it plugged into vag-com various times with no errors popping up!
it runs sweet as a nut now, pulls well, good mpg but still idles all over the place. given up to be honest, would like to sort it but no idea how!  only ever issue i see it causing is if i go to sell her at some point!
