Author Topic: MAF?***New coil in***  (Read 2668 times)
Offline T_J_G
Re: MAF?
« Reply #10 on: 22 May 2009, 16:09 »
MAFs CAN throw up an engine code if they are totally knackered, my mates 2.0 did.
It might be worth you disconnecting the battery for 10 mins or so to let the ECU reset everything, it might sort it out
Tried that as i disconnected the battery for the bora loom
Offline T_J_G
Re: MAF?
« Reply #11 on: 23 May 2009, 18:25 »
Right just had it on VAGCOM
Got a code 17766 (not on rosstech wiki...) says Cylinder 2 open circuit. So swapped it with 1 and that fault code moved to cylinder one.
So th pattern part Mr RAC gave me may be dodgy. No engine light on way back though...so maybe them codes are from them being pulled out?
Tim
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: MAF?***Updated with VACOM scan***
« Reply #12 on: 23 May 2009, 18:39 »
dodgy coil pack mate, get a new one and keep that as a get you home spare for the boot  :wink:
Offline T_J_G
Re: MAF?***Updated with VAGCOM scan***
« Reply #13 on: 23 May 2009, 18:49 »
It was replaced by RAC so I'll get them to refund me and splash out on a genuine one instead, although I'm not sure why the code isn't the usual one. I still think I've got MAF problems as well!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #14 on: 23 May 2009, 22:53 »
hopefully a genuine vag coil pack should cure your fault tim  :wink:
2000 Mkiv GTi 1.8T AGU
Offline T_J_G
Re: MAF?***New coil in***
« Reply #15 on: 26 May 2009, 14:41 »
Getting a cheque back from RAC so put a genuine VW coil pack in today. I'll getit scanned tomorrow to see if any codes are up. Still not boosting properly though.
