Author Topic: I think my diverter valve has had it  (Read 4618 times)
Offline GTiHigh
Re: I think my diverter valve has had it
« Reply #20 on: 21 May 2009, 12:20 »
Question China,
Are you going to remap your ecu ?  if not then just change your recirculating valve for an OEM one...  no need for farting about looking for anything else..
If you are getting a remap then go for the Forge 007p or RTech one....  they're both the recommended ones..
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Pipercross Panel Filter & Smoothed Airbox
Revo Remap - 190 bhp - 225 Torque
Offline china
« Reply #21 on: 21 May 2009, 12:29 »
I will one day get it remaped when i have the money, once i find a cheap insure company, im just worryed about using the car because of the flat spots and hesitation it not all the time . I didnt wont to buy another bosch dv from vw it proberly cost s**tloads. :smug:
Offline GTiHigh
« Reply #22 on: 21 May 2009, 13:53 »
I can understand you there China !
If I was you though ( and because I'm skint ) I'd do a full fault check first before buying anything..
Things I'd check ( apoligies if you've already done this ) :
DV valve - remove the valve and suck the top small pipe - you should hear and feel the valve move,  when you stop sucking the valve should spring back into place....   Suck/blow the other 2 ends - there should be NO movement or leakage of air....   if all checks are fine,  you're DV isn't at fault ( no need to replace )
Hoses - the 3 hoses attaching to the DV,  are there any cracks/splits,  if so replace if needed...  also are the hoses very old,  very soft ? if so when you boot the car then the hoses will be getting sucked in ( loss of power )
Spark Plugs - am I right in saying you've changed the plugs ?  if so did you torque them down correctly ?  worth double checking.
Air filter - is there any sh!t in there ?  check and clean if needed...  Do you have an induction kit ?  if so your car might run like sh!t in town but fine out of town..
Fuel - Do you use cheap crappy watered down petrol ( tesco's bad for this ) if so then you need to get rid of any excess water from your fuel system....  Google water in petrol for a very cheap fix...  simply changing petrol supplier isn't good enough,  you'll need an alchohol ( type stuff ) mixed to your petrol ( only once ).
Nearly forgot...  Throttle Body clean is worth doing to...
Good luck China !!  and let us know how you get on..
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline china
« Reply #23 on: 21 May 2009, 14:28 »
The problem started after i fitted a new k&n induction kit and a new set of plugs the reason im blaming the dump valve is because it sounds different makes a load chatter sound  :embarassed:
Offline GTiHigh
« Reply #24 on: 21 May 2009, 14:48 »
Looks like you answered your own question there China..
When you changed to the induction kit,  did you take it a run before changing the plugs ?
Think you should seriously double check the work you done m8 ! both the plugs and the induction kit.. check all cables, hoses, and electrics you might of touched....  and torque your plugs down correctly..
Also when you changed to the induction kit - I take it you were VERY carefull with the MAF ?...
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline china
« Reply #25 on: 21 May 2009, 15:08 »
year good a mechanics got NVQ level 2 :grin:
Offline GTiHigh
« Reply #26 on: 28 May 2009, 21:52 »
 :grin:
Learnt it all in this fine forum..
Any update ?
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline james2
  • No scammers please.
« Reply #27 on: 30 May 2009, 20:17 »
Its was the diverter valve  :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline GTiHigh
« Reply #28 on: 01 June 2009, 17:54 »
Nice one,  good to hear you've found the fault..
1999 - 1.8T ( AGU )
TB Clean
Forge 007P
Offline cam_paseo
« Reply #29 on: 04 June 2009, 22:49 »
Anyone know where i can buy a forge 007 a lil cheaper or can i only get one from forge?
Also how much is the r-tec one
