Author Topic: Lamba Sensor Problem  (Read 7640 times)
Offline funkyfive
Re: Lamba Sensor Problem
« Reply #10 on: 30 May 2009, 09:20 »
Hi all,
is it easy to fit the lambda sensor if i use axel stands to get under the car? I not lucky enough to have ramps etc..
Offline ace
« Reply #11 on: 30 May 2009, 10:41 »
yeah u will need to jack the front of the car. the sensor is at the front of the cat unscrew the sensor and follow the wire to the other end.
i used home made ramps, 2 planks of wood on some bricks!!!!!!!
Offline funkyfive
« Reply #12 on: 30 May 2009, 12:19 »
Cheers Ace lol like the improvised ramp idea!!!!
Offline ace
« Reply #13 on: 30 May 2009, 12:28 »
these things have to be done sometimes!!!!!
Offline funkyfive
« Reply #14 on: 31 May 2009, 10:21 »
Cannot believe it ace, I could not undo the sensor. Looks like a garage job again?
I also noticed the cable on the lambda was knackered.
