Author Topic: Lamba Sensor Problem  (Read 7643 times)
Offline funkyfive
« on: 20 May 2009, 20:54 »
VAG-COM Version: Release 409.1-US
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01: Engine
   Controller: 037 906 025 A
   Component: SIMOS 4S           1823
   Coding: 00000
   Shop #: WSC 01317
1 Fault Found:
00537 - Lambda (Oxygen Sensor) Regulation
            18-10 - Upper Limit - Intermittent
Readiness: N/A
I got the error above when i used my VAG.COM kit from Ebay (Totally recommended).
Whats the best actions to do; take it out and clean it or just replace it?
Also does anyone have a "how to change" process for changing this sensor?
Offline Adam
Re: Lamba Sensor Problem
« Reply #1 on: 20 May 2009, 20:55 »
Did you clear the code and rescan it?
Down Hill From Here.
Offline ace
« Reply #2 on: 20 May 2009, 20:58 »
i would try clean it first and clearing the codes. if it still comes up, the sensor is easy to change. jack the car up and u will see the sensor near the front of the cat, unsrew it carefully and follow the wiring. unclip it and put the new  the new sensor in. should be around £45-£50 from gsf or euro
Offline funkyfive
« Reply #3 on: 20 May 2009, 21:03 »
Yeah I cleared the code and rescaned it and it came up straight away.
Offline funkyfive
« Reply #4 on: 20 May 2009, 21:40 »
Found this info on ross-tech wiki
  00537 - Lambda (Oxygen Sensor) Regulation: Upper Limit
Possible Symptoms
    * No Lambda control
    * Engine running problems
Possible Causes
    * Short to Ground (WHAT DOES THIS MEAN?)
    * Injector defective (blocked)
    * Fuel pressure regulator defective
    * Fuel pump defective
    * Fuel tank empty
Possible Solutions
    * Check Lambda probe and Lambda control
    * Check injectors (N30...N33)
    * Check fuel pressure regulator
    * Check fuel pump
    * Check fuel level in fuel tank
Know i even more confused, what to do first?
Offline funkyfive
« Reply #5 on: 21 May 2009, 22:38 »
Possible Symptoms
    * No Lambda control
Possible Causes
    * Fuel tank empty
Possible Solutions
    * Check fuel pump
Can anyone help?
Offline Adam
« Reply #6 on: 21 May 2009, 22:41 »
Check the voltage of the sensor- 0.2volts (lean) or 0.8volts (rich)
Offline funkyfive
Re: Lambda Sensor Problem
« Reply #7 on: 23 May 2009, 08:19 »
Sorry Adam how do i do that and where is the lambda located?
I am virgin to DIY mechanics
Offline funkyfive
« Reply #8 on: 25 May 2009, 07:52 »
I was quick to answer before and cleared and rescaned, the lambda sensor is fine. So no issue there.
Offline funkyfive
« Reply #9 on: 28 May 2009, 13:16 »
Damn ebay company sent me the lambda sensor, do i fit it or not?
Why was there a lambda sensor error in the first place?
