Author Topic: Mk 2 16v starting problem  (Read 2421 times)
Re: Mk 2 16v starting problem
« Reply #10 on: 15 June 2009, 09:11 »
have you blocked off the 2 large holes in the inlet pipe/airbox where the over-run valve was? you'll have a massive airleak otherwise
Offline Procomp
« Reply #11 on: 15 June 2009, 12:55 »
Yeah....if there is any air leaking into the induction system, you'll not be able to start the car.  Make sure it's all as it should be and sealed up tight or any holes are blocked.
