Golf mk2
Rev Counter Not Working
Topic: Rev Counter Not Working (Read 20267 times)
carlos85
Here all the time
Re: Rev Counter Not Working
Reply #10 on:
19 May 2009, 17:46 »
which is the TCI-H unit?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #11 on:
19 May 2009, 17:58 »
its the 7 pin thingy bolted to the top of the ecu bracket, its under the plastic trim over the scuttle area on the driver side
looks like zis
carlos85
Here all the time
Reply #12 on:
24 May 2009, 16:52 »
i've just cut out the mk3 speedo sensor plug and found that one of the cables was wired to a grey/red wire that is on G1 on the fuse box
rubjonny
10k hero
Reply #13 on:
26 May 2009, 10:34 »
have a look at the fusebox faq, you should be able to figure out what goes where
carlos85
Here all the time
Reply #14 on:
26 May 2009, 12:51 »
i've just had a look and can't find the cable on the list
rubjonny
10k hero
Reply #15 on:
26 May 2009, 13:17 »
G1
12- red/blk- ignition coil pin 1 and/or TCI Unit (Digifant control relay)
U1
6 - grn - Dash plug pin 10 (rev counter pin 1)
carlos85
Here all the time
Reply #16 on:
26 May 2009, 14:32 »
i mean for the grey/red cable, it's next to the red/black one on the plug
rubjonny
10k hero
Reply #17 on:
26 May 2009, 14:41 »
from the MK3 fusebox listing (its on page 3)
F
4 - brn - vehicle speed sensor pin 3
G1
4 - blk - ECU pin 38, gearbox speed sensor, ignition coil pin 3
11- wht/blu - vehicle speed sensor pin 2
carlos85
Here all the time
Reply #18 on:
26 May 2009, 14:56 »
so i need to check
G1
U1
rubjonny
10k hero
Reply #19 on:
26 May 2009, 15:51 »
yes, thats the rev counter wire.
coil -> G1 -> inside fusebox -> U1 -> dash clocks rev counter
Golf mk2
