Author Topic: Fluttering noise  (Read 4735 times)
Offline gaz_marshall
Re: Fluttering noise
« Reply #10 on: 18 May 2009, 20:00 »
oh dear  :sad:, so there should be no noise when you change gear? how would i go about checking this out?
do you mean something like this?
http://cgi.ebay.co.uk/FORGE-FMCL007P-RECIRCULATING-DIVERTER-DUMP-VALVE-1-8T_W0QQitemZ320371834400QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item320371834400&_trksid=p3286.c0.m14&_trkparms=72%3A1689|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
cheers
gareth
jamie16v
« Reply #11 on: 18 May 2009, 20:15 »
you will still hear like a faint hissing noise whatever happens, the valve is releasing pressurised air into a part of the system thats not pressurised so will make a little hiss, just not as loud as a valve that lets the pressure straight out into the air. therefore it kind of makes sense why an enclosed DV like the ones we are using are quieter.
Offline Dubbz
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
« Reply #13 on: 18 May 2009, 20:28 »
ok thanks for the info, much appreciated! if i purchase a forge are they hard to fit (me being a novice when it comes to mechanics).
gareth
Offline jtomlin
  • 1999 AGU 1.8T GTI
« Reply #14 on: 18 May 2009, 20:43 »
real easy to fit! should be a fiting guide somewhere id imagine, if its chattering it means air is getting forced back into the blades of the turbo, sounds cool but can kil the turbo!
« Reply #15 on: 19 May 2009, 10:56 »
thanks, i've ordered the valve so it should be here tomorrow- we'll see if the noise disappears once fitted. does it come with crimps etc or do i have to go purchase them?
cheers
gareth
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #16 on: 19 May 2009, 11:14 »
Problem solved! :grin:
Mechanic mate of mine had fitted my forge split-r the wrong way so I flipped it to right position and get a nice whoosh sound now when I change gear  :cool: no more fluttering!!
So in answer to my own question and few others there should be no flutter!! :nerd:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
« Reply #17 on: 31 May 2009, 18:47 »
Just thought I'd also add, fitted the forge dv on the weekend, no flutter and for some reason fuel consumption has decreased- marvellous!
Offline james2
  • No scammers please.
« Reply #18 on: 31 May 2009, 22:25 »
does any one know the inside diameter of a silicon pipe to fit a dump valve to a 1.8 agu i got a 25mm id pipe but it a bit big is it about 23mm id .cheers. :huh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Dempsey
  • Fabia vRS SE, Blue, number 553
« Reply #19 on: 02 June 2009, 18:36 »
i have got an induction kit on mine, and i can hear a dump kind of thing when i change gear, im guessing this is wrong then?
Audi TT Polished Comps with 205/40/17 tyres for sale £400 - http://www.golfgtiforum.co.uk/index.php?topic=142136.0
