Author Topic: Traction control on the 16v?  (Read 4722 times)
Offline Paul86S2
Re: Traction control on the 16v?
« Reply #40 on: 06 June 2009, 23:34 »
Hit the redline then change up = no problem.
Isn't that what the red marks are for on the rev counter - to tell you when to change up.
Paul
Offline LostBok
« Reply #41 on: 07 June 2009, 08:13 »
I remember a few guys off the old veedubbers forum messing aroudn with these and disabling it on the 16V and VR6 cars as it's a pretty rudimentary (and killjoy) system....
8v = no traction control, even if it has ABS.
16V and VR6 both have the same / virutally identical traction control system.
It uses the same sensors as the ABS, so if you ABS is indeed knackered, then there's a fair chance it won't work as ABS usually breaks at the sensors end, not the control unit.
Traction control has what I am pretty sure is a separate control unit and if I remember correctly, it's located under the rear seat somewhere.
It is possible to disable TC by disconnecting this, but not sure on the impact on ABS or if you have to just replace the 16V/VR6 TC unit with an 8V ABS unit to get ABS only.
LOSTBOK
Audi A4(B6): 2.5TDi Quattro Sport: Factory fitted Xenons, BOSE, and full sports leather "Soul Black / Titanium".
Mods: All OEM: S-Line bodykit, RNS-E, Bluetooth, Audi R8 FBMFSW, SDS-High voice control, full DIS, cruise control, Aero wiper mod.
In progress: 5 x OEM S4/Ronal 'Avus' 18's & 235/45ZR18 Toyo Proxes T1-R (bah! wheels delayed until WC 27-JUL-09)
Researching: Colour DIS, Freeview and DAB tuner with iPodvid/PSP/AV in for the RNS-E.
