Author Topic: Trouble starting after a longish journey  (Read 1623 times)
Offline maxp
  • J reg 8v digi gti
Re: Trouble starting after a longish journey
« Reply #10 on: 18 May 2009, 13:53 »
Changed the blue sender about 4-5 months ago for an official vag one.
I remember pulling it off a week or so ago and the engine revs started surging so i think its working.
New ECU Time? Clean out the MAF?
« Reply #11 on: 18 May 2009, 14:16 »
pull vac pipe off the fpr and crank it, heard of these failing internally and spraying fuel out vac connection making mixture too rich!  obv take all precautions when doing this, try it on a cold engine and have a rag round it to soak up any fuel.
next step is to check what is actually happening when the problem occurs. check if you have spark (lay king lead on rocker cover while cranking) then check if you have fuel (whip spark plug out, see if bores smell of fuel)
« Last Edit: 18 May 2009, 14:19 by rubjonny »
Offline maxp
  • J reg 8v digi gti
« Reply #12 on: 19 May 2009, 23:11 »
For testing the fpr, is the way to do it with the key on 'one click' i.e. electronic system (fuel pump etc) active, vac pump out, then start cranking the engine?
« Reply #13 on: 20 May 2009, 09:30 »
just disconnect it and try to start the car, iirc it will run with the vac line off but not so well?  either way if fuel comes out when running/cranking you know its bust :)
