Author Topic: Best manuals to buy for Mk1  (Read 1867 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 09 August 2004, 11:32 »
hi
I've had a look around at found the following manuals for the Mk1's which one is the best to buy?
Haynes:
Improve & Modify Golf & Jetta (inc GTi) (Re-issue)
You & Your VW Golf GTI
VW Golf and Jetta Restoration Manual
« Last Edit: 09 August 2004, 11:33 by Madone »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline 8valvesgood
Re:Best manuals to buy for Mk1
« Reply #1 on: 09 August 2004, 12:46 »
haynes covers most components in brief, doesn't go into the fuel system much but provides decent break downs of trim and general upkeep.
improve and modify is so old the modifications such as whale tale spoiles and golf rear sun deflectors might not be to your style doesn't really give loads of indepth ideas out.
I have a different restoration book to the one mentioned and i only find a few areas that are more indepth than others and vice versa, compared to haynes.
You can't polish a turd
Offline Joester
« Reply #2 on: 09 August 2004, 13:34 »
I have got the Restoration manual.
I find it is quite useful when used alongside the Haynes Workshop Manual (the workshop manual I have is very old and very rubbish).
The author (Lindsay Porter) really knows all the little tricks to dismantling/reassembling, so I have found that I am less prone to making silly errors (such as snapping bits of trim, etc) whilst working on the car.
It is also quite realistic in terms of what you should and should not attempt, for example replaciong a cabrio hood - don't touch it with a bargepole.
Dinky
« Reply #3 on: 09 August 2004, 15:20 »
I have this
http://www.amazon.co.uk/exec/obidos/ASIN/0837603668/202-4360582-6730207
was recommended by a few peps on here wen i was lookin for a manual. :)
Dinx  :-*
