Golf mk3
hardmonkeys
16v & VR6 Gearbox
Topic: 16v & VR6 Gearbox (Read 1768 times)
ace
16v & VR6 Gearbox
16 May 2009, 14:44 »
basically, my bro-in-law has a dead 16v and has been given a vr6 engine, is it a straight swap???
can u use a 16v gearbox with a VR6 engine???
also would we need a new ecu as well???
Cable
Re: 16v & VR6 Gearbox
16 May 2009, 14:47 »
yh new ECU and they are the same gearboxes
ace
16 May 2009, 14:49 »
thats good news
always thought they were different gearboxes
Paul86S2
16 May 2009, 15:40 »
I would check this if i was you. I'm fairly certain they are different.
Paul
Mikester
Forum addict
Civic Type R
16 May 2009, 16:19 »
I think the boxes will be different, but 16v and VR6 both use a hydrolic clutch so there shouldnt be to much of a fitting problem. Might have to use use the 16v fly wheel though?
Not sure but wouldnt think it would be that hard a fit.
Last Edit: 16 May 2009, 16:28 by Mikester
Khare
Serious forum addict
The bear that khares
16 May 2009, 16:25 »
think i heard RJ say something about 16v and vr6 having different bell housing or something.
ace
Reply #6 on:
16 May 2009, 16:36 »
Quote from: Khare on 16 May 2009, 16:25
yeah just been on vr6oc they say the same thing, but its not a major issue to change it from what i gather.
mat-ryder
Here all the time
Reply #7 on:
17 May 2009, 03:37 »
im sure its the same 02a box in both
Wayne
Sir Postalot
Reply #8 on:
17 May 2009, 10:16 »
Different bellhousing I believe.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #9 on:
18 May 2009, 08:01 »
yes bellhousing is completly different, the internals are the same except for gear ratios though. the existing hydro clutch/cable shift bits will swap over
Golf mk3
hardmonkeys
16v & VR6 Gearbox
