Author Topic: !DUMPF!  (Read 2189 times)
Offline paulydixon
!DUMPF!
« on: 14 May 2009, 17:25 »
That's what noise part of my engine makes when i'm in reverse or when i let off the clutch quite sharp...it's pretty violent actually
Engine mount?
Offline Khare
  • The bear that khares
Re: !DUMPF!
« Reply #1 on: 14 May 2009, 17:30 »
could well be. My gearbox mount is fooked so when i reverse or when i used engine braking agressively, gearbox hits the inner wing and makes a clunk sound. Stick handbrake on, get a mate to do reverse with handbrake on, while you look under the car.
Offline paulydixon
Re: !DUMPF!
« Reply #2 on: 14 May 2009, 18:52 »
Actually that throws up another Q. What, in the hell, would my exhaust be rattling off under heavy breaking and on start up?
Re: !DUMPF!
« Reply #3 on: 14 May 2009, 19:08 »
Rear axle is the most common area.
Offline Khare
Re: !DUMPF!
« Reply #4 on: 14 May 2009, 19:29 »
as wayne says. Rear axle is most common but could also be the heatshield along the transmission tunner.
Offline paulydixon
Re: !DUMPF!
« Reply #5 on: 14 May 2009, 19:50 »
 :laugh:
I've eliminated the head shield already  :grin:
But now that you say that, it actually only started wence i wound the coils down, darn i hate the noise but adore the lowes
Offline Khare
Re: !DUMPF!
« Reply #6 on: 14 May 2009, 19:56 »
if it only started when u wond coilies down then its rear axle. VERY common problem. Either raise the exhaust up abit with new exhaust hangers/polyutherane ones, reposition the pipe over the rear axle, or raise the car abit.
Re: !DUMPF!
« Reply #7 on: 14 May 2009, 20:08 »
On mine the clamp was fitted so the nuts were banging the axle beam, turned the clamp over and it was gone.
Offline paulydixon
Re: !DUMPF!
« Reply #8 on: 14 May 2009, 20:30 »
Cool i'll give all that a shot at the weekend! cheers brothers!
