Author Topic: SILL Replacement  (Read 8687 times)
Offline danny_p
Re: SILL Replacement
« Reply #10 on: 16 May 2009, 18:23 »
so i has the right to comment wow.
support it, measure it,   cut it,  offer up and tack, measure up.  weld, measure more, weld  measure more weld more ect
all the VW's have gone bar 1.
Offline Ben Lessani
« Reply #11 on: 16 May 2009, 18:58 »
Sounds about right, but you forgot to say make silly faces whilst avoiding grinding sparks even though you're wearing a full face mask - or is that just me
Offline uber pikey
« Reply #12 on: 16 May 2009, 22:50 »
Thanks Ben, I knew there would be someone that was able to help me in the right direction not just waffle through pretending to be any good.
I saw it so I took it.
Offline Ben Lessani
« Reply #13 on: 17 May 2009, 01:01 »
You're obviously a bit new here - a few tips are not to get so easily offended.
DiamondHell and DannyP both know a lot more about this than I do - but they can't offer advice unless you can fully describe the situation.
As per the forum motto - expect help and sarcasm and try not to bite the hand that feeds you ;)
Offline sidecarphil
« Reply #14 on: 17 May 2009, 12:21 »
i replaced the sill on a sh1tty old fiesta once
make sure you tack both ends in place before you start seam welding
or the panel bends with the heat and by the time you get to the other end it is bent like a bannana  :grin: :grin:
