Author Topic: vag com  (Read 906 times)
Offline swalk999
vag com
« on: 13 May 2009, 20:12 »
i bought a version of vagcom from ebay and it told me that I had a faulty lambda sensor which was replaced but car is still lumpy ..
put it back on vag com and it says i still have lambda sensor fault .. 00537 & 00533
when i reset the codes minutes later they return HELP
 :cry:
Offline grimmer
  • www.check-light-on.co.uk
Re: vag com
« Reply #1 on: 13 May 2009, 20:52 »
The 00533 is the idle control valve, and the 00537 is more to do with lambda control system, if lambda is defective you would have:
Oxygen Sensor:
No Signal
I think maybe some golfs are preheated sensors and are relay controlled, perhaps this can be your problem
MK3 GOLF GTI 8V  now converted to 16v!!
