Author Topic: Because i'm feeling daft...  (Read 1465 times)
Offline paulydixon
« on: 13 May 2009, 18:40 »
Can i fit some sort of dump valve to my 1.9 td?
I think i'm bored of it being matt black also so i'm going to give it a flash over with Nato green  :sick:
Offline Adam
Re: Because i'm feeling daft...
« Reply #1 on: 13 May 2009, 18:42 »
If you were it wouldn't sound like a petrol dump valve and it would need to be electronically controled. Oh and cost $£$£
.............why do it?
If you are serious about it here is some information -
http://www.zen19051.zen.co.uk/prod01.htm
Down Hill From Here.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 13 May 2009, 19:20 »
I have a TDI and sometimes wonder if i should do it... Not because i like the sound of it so much... for the same reason i play the birdy song full blast through town... hmm.. its good to be diffrent.
It can be done but as said before it needs electronics to control the vac line.  Some (better ones) Use a control module that picks up a signal from the ECU to know when to upen the vac line, others use a switch on the throttle cable.  If you get a MK3 TDI specific kit it will have the control module.  They never sound the same though but with the ECU line the valve opens and closes better so sounds a little nicer, raising boost can make it sound better, TDI's run high boost compared to a petrol anyway, they just lack the throttle plate,  Now if you can manage to fit on of them in... could see some interesting results (and noises)  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline paulydixon
« Reply #3 on: 13 May 2009, 19:22 »
Likeyou say's fun to be odd!.....butthat is an extreme amount of effort.
Hmmm, i might just buy something gash off of e bay instead
Offline Rmachines
« Reply #4 on: 13 May 2009, 19:28 »
haha, i like you... you remind me of me...  Have an urge to buy cheesy gash  :grin: :grin:
Offline paulydixon
« Reply #5 on: 13 May 2009, 21:52 »
For some reaon i felt the need to buy a siren which has a microphone and plays animal noises?
Who needs a dump valve when you can has cows!
warrrrrpppppp......MOOOOOOOOOOOOOOOOOOO!
Offline Adam
« Reply #6 on: 13 May 2009, 21:57 »
 :grin: :huh: :undecided:
Offline Mikester
  • Civic Type R
« Reply #7 on: 14 May 2009, 16:19 »
Mate had one of these in his car, its bloody hillarious!!
But dont mount it too low, as water splashing and the speaker dont go well.
Offline paulydixon
« Reply #8 on: 14 May 2009, 17:23 »
I was actually trying to get hold of an oldy worldy sh!tty looking roof rack to mount it on?
