Author Topic: Can anyone tell me what these dials are out of?  (Read 3474 times)
Offline Mikester
  • Civic Type R
Re: Can anyone tell me what these dials are out of?
« Reply #10 on: 13 May 2009, 18:39 »
As john said 16v and vr6 clocks go to 160 mph and the 8v clocks goto 140mph so the clocks you have got in are the right clocks for your car... :smiley:
This is true 100%.
Ani clocks were white, and i think early to late dials changed the design slightly as i have seen different ones in different cars of the same engine type. But aslong as u have the correct speedo for the car, then they will read right.
Offline mk3valver
« Reply #11 on: 13 May 2009, 18:50 »
It does read about 5-7 mph out as per my navman but I cant remember which way? And mike I'm not sure whether these are the right dials as it's a 16v and the clock's read 140? Unless Vw put 140 in later models for some reason it looks like I have the wrong clock's!
Offline mk3valver
« Reply #12 on: 13 May 2009, 18:54 »
Sorry mate after reading above post again are you saying that they may have changed the dials in later model's?
Offline Mikester
  • Civic Type R
« Reply #13 on: 13 May 2009, 18:58 »
Well i have an 8v, same dials as you but the petrol gauge is diferent, with 4 red lines.
The speedo will read out, its an old car mate. Mine is about 5mph out 70mph.
The dials are deffinaly the correct 8v dials, what year is your car?
You dont have a problem, so dont worry about it. There were a lot of developments in the eira that the mk3 was made, hence why they differ early to late.
Offline mk3valver
« Reply #14 on: 13 May 2009, 19:04 »
Yeah I put it down to the calibration at the time I was just repling to the question. It's a 97 P 16v. Is there anyway of me checking a part number off the clock's too the rest of the car to see if their right? It's not a major issue it's just pecking my head!
Cheer's for the reply's anyway!    :smiley:
Offline Mikester
  • Civic Type R
« Reply #15 on: 13 May 2009, 19:11 »
Lens 16v clocks:
« Last Edit: 13 May 2009, 19:13 by Mikester »
Offline mk3valver
« Reply #16 on: 13 May 2009, 19:21 »
Oh good, I feel better now! What year is his?
Offline Adam
« Reply #17 on: 13 May 2009, 19:39 »
Len's is a P or an R reg.  :undecided:
Down Hill From Here.
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #18 on: 13 May 2009, 19:44 »
Sorry mk3valver i thought ures was a 8v m8.Heres a pick of my clocks my car is a 1997 R-reg 16v.I was told that the plugs are different on the 16v-vr6 clocks to the 8v im not sure but if there not id try get meself some anniversery clocks in white  :smiley:
Golf Gti
Offline boneybradley
  • Back in a Mk3...
« Reply #19 on: 13 May 2009, 20:14 »
any mk3 clocks will plug in and work fine..but the 16v should have 160mph on the speeedo (although some early models have a speedo that starts at 10mph with a needle rest)
