Author Topic: electric window squeal  (Read 2562 times)
Offline OakeyDoak16v
Re: electric window squeal
« Reply #10 on: 12 May 2009, 22:17 »
okay cool will try and get some . Disapointing tho as i was under the impression that wd40 fixed everything. :grin:
Offline Ben Lessani
« Reply #11 on: 12 May 2009, 22:40 »
WD40 is good (as is GT85) but you obviously have to use the right product for the right application. As a rule of thumb...
GT85/WD40 for bike chains, dispersing water and for applications where there isn't heavy frictional contact (otherwise it just wears off).
Moly grease for CV joints / wheel bearings
Copper slip for bolt threads, contact faces (ie. wheel > hub to stop it sticking on) ...
Standard grease for movey bits, door hinges etc.
Lithium grease for wheel bearings and high heat applications
