Author Topic: Mk3 oil leak from gearbox?  (Read 1595 times)
Offline mk3valver
« on: 11 May 2009, 18:34 »
Hi, last tuesday I had my cam cover gasket replaced due to a mega bad oil leak. During the following day's I noticed a very minor few drops of oil when I moved the car in the morning, but put this down to not having cleaned the engine yet and this just being the remainder dripping off the bottom. On saturday I got my timing belt done. When we got underneath it there seemed to be a leak coming from the gearbox where it meet's the engine, the mechanic told me a seal had gone between the engine and the gearbox and this mean's that when I get this done I'm going to have to replace my clutch as more than likely when he takes it off it will contaminate it and it will slip! And then need to be done anyway!
Is this right? Any advice is more than welcome just looking for a second opinion really without taking it to another garage!
Offline danny_p
Re: Mk3 oil leak from gearbox?
« Reply #1 on: 11 May 2009, 19:51 »
cabel change box  the clutch is normal way round so flywheel will protect clutch from oil if its the cranck end seal but its very easy time to change clutch and it probaly well worn so daft not to do it
all the VW's have gone bar 1.
« Reply #2 on: 11 May 2009, 20:01 »
If the crank seal is leaking, I would 100% fit a new clutch.
Offline mk3valver
« Reply #3 on: 11 May 2009, 20:23 »
Cheer's, just wanted a second opinion! Has anyone fitted a competition clutch before? And if so is it worth me fitting 1?
Offline danny_p
« Reply #4 on: 11 May 2009, 22:08 »
is it a compotion car ?  if not don't bother the same clutch will hold a 20vt happily so unless it's magorly modifyed it'll be just fine with a std one
Offline mk3valver
« Reply #5 on: 11 May 2009, 22:09 »
Thank you   :smiley:
