Author Topic: Dreaded Oil Leak ... :( :( :(  (Read 2823 times)
Offline DubSociety
« on: 06 May 2009, 16:42 »
Had a minor oil leak for ages now, but finally got round to being able to afford to fix it. It was very hard to trace, but I had the oil filter replaced, sump gasket replaced put everything back together but we can see the oil is coming from behind the oil cooler ... so went to VW today and ordered an O-Ring and a Gasket that connects straight to the engine block ...
My question is ... is it common for the oil cooler to be damaged? because luckily the seals etc only cost me £6 but the oil cooler costs bloody £100!!
Offline Horney
Re: Dreaded Oil Leak ... :( :( :(
« Reply #1 on: 06 May 2009, 16:44 »
I had to do the same O ring on my Rado recently, they persish with age.
nick
Offline Adam
Down Hill From Here.
Offline DubSociety
« Reply #3 on: 06 May 2009, 23:07 »
Fair enough, I hope its just the o-ring then ... my cars engine has had A LOT of money spent on it now if I look back at another electrical problem I had last year, I hope she's happy lol!
« Reply #4 on: 06 May 2009, 23:09 »
Should really only need the o-ring, make sure you clean it all up before fitting the new o-ring plus make sure it is not pinched in any way.
Offline Amzy-Bear
« Reply #5 on: 07 May 2009, 00:33 »
that might be whats wrong with mine :(
its been leaking for ages, havent had time 2 sort it, al i know is its not the sump or oil filter !
:D
Offline DubSociety
« Reply #6 on: 07 May 2009, 06:28 »
One of my mates is working on my car along with a few other knowledgeable polish mechanics that give him a hand if he struggles on anything, he's on paid work experience for a year at a nearby garage so Im getting the work done with a bit of a discount aswell and I get to stay with my car and point out anything else I want done while the cars on the ramp ... come to think of it, I need to get the ABS sensors checked out so I might go down to the garage with a multimeter and do a reading on it while he works on replacing the o-ring on friday.
