Author Topic: vr6 gear change  (Read 791 times)
Offline oliver07
  • golf gti T 200BHP
vr6 gear change
« on: 04 May 2009, 10:48 »
any ideas why gear change is so long as my last vr6 was a lot shorter throw.my gears are working fine do you think there is something worn outl
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: vr6 gear change
« Reply #1 on: 04 May 2009, 14:32 »
My 16v and diesel all have cable change and they are really sloppy compared to the rods.  I presume the cables stretch with use?  there is a rebuild kit you can get, i dont know if it comes with as much as the rods as there are less bushes etc... but as both yours were VR6 it must be down to wear and tear rarther than a diffrent setup.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
