Author Topic: coilovers  (Read 3395 times)
Offline parrotveasey81
Re: coilovers
« Reply #20 on: 06 May 2009, 21:33 »
???? still dont know,cheap or dear shame you cant try before you buy.just ordered some polybushes so will fit these and see how it goes,if all goes ok then i will save up for some fully adjustable ones then it would just be a case of playing with them to get it how i want.any pointers to how i up load pics.
drive it like u stole it,brake it then mod it
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Re: coilovers
« Reply #21 on: 06 May 2009, 21:38 »
have a read of this, it helped me out, pretty straight forward
http://www.golfgtiforum.co.uk/index.php?topic=85911.0
Offline sidecarphil
Re: coilovers
« Reply #22 on: 07 May 2009, 19:39 »
what do i put on the threads of the coilovers to stop the screw seizing up ??
any ideas greatly welcomed  :wink: :wink:
if i use grease the sand and road crud will stick to it  :undecided: :undecided:
Re: coilovers
« Reply #23 on: 07 May 2009, 20:23 »
I used copperslip but have also heard people using waxoil.
Offline Ben Lessani
Re: coilovers
« Reply #24 on: 07 May 2009, 21:23 »
I used copper slip too. Motorbike chain wax is recommended though.
But if they are valuable ones, get a set of shock socks to keep them dirt and moisture free!
VeeDubGTI16v
Re: coilovers
« Reply #25 on: 07 May 2009, 21:25 »
i use waxoil, seems really good so far!
Offline sidecarphil
Re: coilovers
« Reply #26 on: 07 May 2009, 21:28 »
got gallons of chain wax :) i'll give that a go
skint now , payed a fortune for good coilovers  :grin: :grin: :grin:
Offline Ben Lessani
Re: coilovers
« Reply #27 on: 07 May 2009, 23:55 »
I put a big thick tonne of it on - all the dirt on the road sticks to it though! eBay used to have tones of coil over covers on there. They're only simple bits of plastic/nylon/polyester sheet - but it would keep the grit from sticking!
And come MOT time, most testers think the shocks are leaking because they're covered in black crud.
