Author Topic: Snow Foam  (Read 12229 times)
Offline ifti
Re: Snow Foam
« Reply #30 on: 10 May 2009, 17:07 »
So if I have bugs etc stuck to the front of my car, and the car is generally a little dirty, will using a snow foam and lancer mean I dont need to wash with a mitt and rinse etc?
All I need to do is snow foam the car, rinse, then dry?
Offline Guy
Re: Snow Foam
« Reply #31 on: 10 May 2009, 18:23 »
Why does it have to be ph neutral guys?
it doesn't have to be... but it is kinder to the fishes and the paintwork (non-acidic/alkali - corrosive)
it won't replace your 2BW completely... but you could use it midweek... you still need the agitation for your 'proper' wash to shift heavy/baked on contamination
Offline drapergti
Re: Snow Foam
« Reply #32 on: 11 May 2009, 09:54 »
I use a cheap Karcher and the cyc lance attachment.
Offline monzablue16v
Re: Snow Foam
« Reply #33 on: 11 May 2009, 13:10 »
I have a Karcher K7.85 and the cyc lance, now using PH neutral snowfoam mixed depending on what I am doing. The Mini one had a good dollop of CG strong wash in there to clear up as it had not been waxed before.
I always Foam twice and then do the 2BM and a rinse with RO DI water :)
