Author Topic: Does this look rite for a GolfGti 8v?  (Read 1343 times)
Offline lee_lee08
  • 1996 GTI 8v
« on: 02 May 2009, 21:21 »
Rekon I can do these myself but are they the rite parts? for a 2.0 8v 1996 P reg Golf GTi?
MMW719/30    OIL FILTER ALTERNATIVE ???      G3 2.0 8v MPi 8/94 >2/99         £3.45
98071       ANTIFREEZE-5L       GENERAL USE         £13.95
11638       SEAL-SUMP DRAIN PLUG       G3 All Ex.16V         £0.20
98082A       FUCHS XTR SEMI SYNTHETIC 10W40 OIL 5L ???      GENERAL USE-SEMI SYNTHETIC(NOT FOR PD ENGINES)   £13.50
98048A       FUCHS TITAN SYN GEAR OIL 75W-90 4 L    <<<Im assuming its for gearbox?    AS REQUIRED (GL4/GL5 SPEC)         £15.50
I just want to go gsf and hand over this list?
Offline boneybradley
  • Back in a Mk3...
Re: Does this look rite for a GolfGti 8v?
« Reply #1 on: 02 May 2009, 21:53 »
looks good to me..but why get 5 litres of universal anti freeze (when you can get 2 litre of vw spec stuff for less?) and you only need about 2 litre of gear oil
Christo77
« Reply #2 on: 02 May 2009, 22:00 »
Hiya..I've bought all of these items in the last couple of years,  Unless your really having to scrape the barrel financially these items aren't overly expensive at your local VW main dealer,
I always go for the VW Quantum synta silver engine oil, i think i paid £17.00 for five litres last time and you know it's good stuff!
Oil filter was about £5.00, the sump bolt about the same and sealing washers are pence each.
Again the antifreeze and gearbox oil i bought from VW and really it wasn't that expensive as i remember..and again your getting quality parts.
If you need the likes of new brake discs, pads or any other larger type machined items then yes it makes sense to look at gsf parts..
Christo
Offline lee_lee08
  • 1996 GTI 8v
« Reply #3 on: 02 May 2009, 22:01 »
Thanks BB
I change gearbox oil regularly as shes getting a little stiff! and it needs 2 litres apparently! (thats what ive put in every time ive changed it?)
Dont tell me you sold yours? the black 1?
Offline lee_lee08
  • 1996 GTI 8v
« Reply #4 on: 02 May 2009, 22:03 »
cheers christo!
Mite have talked me into buyin oil and filter from steelers!
Christo77
« Reply #5 on: 02 May 2009, 22:09 »
Hehe..yep you might call them stealers with regards to many and particular parts but general service items are reasonable i've found, and your getting the best quality,
Christo
  • Back in a Mk3...
« Reply #6 on: 02 May 2009, 22:13 »
t.b.h the filter listed is made by mann and hummel (vw's o.e supplier) and the oil is castrol but rebranded.... as long as you get quality known brands you'll have no issues...
oh yeah golf is now sold and passat is here!! :wink:
