Author Topic: someone please help  (Read 1289 times)
Offline gazpowells
someone please help
« on: 02 May 2009, 15:44 »
could someone with a late mk3 2.0 16v ABF please help me  :smiley:
would you please look at your Diagnostic plug and tell me how many wires ,colour and the position of the wires in the plug
thanks
Offline gazpowells
Re: someone please help
« Reply #1 on: 03 May 2009, 06:39 »
someone please?  :smiley:
Offline mk3valver
« Reply #2 on: 03 May 2009, 13:53 »
Dont quite know where you mean? If you give me a good description i'll have a look mate
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 03 May 2009, 15:29 »
There is only 4 wires into the 16 pin connector,
From 16 pin socket to ECU??? i think
T16/16 Red/black  - Fused 15A  - to ECU???
From 16 pin socket to Earth connector
T16/4  Brown         Leads to Earth connection 1, in dash panel wiring harness
From 16 pin socket to Self-diagnosis wiring junction, above the relay plate
T16/15 Yellow        Leads to 2-pin connector, above the relay plate
T16/7  Grey/White  Leads to 2-pin connector, above the relay plate
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline gazpowells
« Reply #4 on: 03 May 2009, 16:06 »
thanks for your help  :smiley:
I got it working now, have run vag-com and have loads of faults 2 fix now  :sad:
