Author Topic: Well And Truely ****** OFF !!!  (Read 1991 times)
Offline BIGSTEVEGTI
« on: 01 May 2009, 17:30 »
Rite i've had enough of my motor !!! It's been idleing to high and i've tried loads Temp Sender, Relay's, Idle valve and Throttle sensor and none of this have made swet f a of a difference
So please help before you hear on the news of a crazed man blowing up he's golf lol
Offline loki86
Re: Well And Truely ****** OFF !!!
« Reply #1 on: 01 May 2009, 18:19 »
have you tried the lamba sensor or whatever it called
Offline grimmer
  • www.check-light-on.co.uk
« Reply #2 on: 01 May 2009, 19:33 »
one thing is too make sure when u changed the idle control valve u had the exact part  number from the orginal one and werent from a audi or something similar, this can cause high idles
second, u may have a air leak drawing in air can cause high idling, spray brake cleaner around pipes while engine running to see if engine note changes.
thirdly, i do car diagnostics, on one of my code readers on mk3 digifant ecus there is a function that re-calibrates the idle speed electronically and generally lowers it and sorts it out basically, u could try and reset your ecu, disconnect battery for 30 mins, and let ecu learn again.
Also worth checking acceralerate cable isnt too tight, theres a adjustment on the plastic ribbed part, little clip can be moved down the ribbed bit
Hope something helps
MK3 GOLF GTI 8V  now converted to 16v!!
Offline BIGSTEVEGTI
« Reply #3 on: 01 May 2009, 22:06 »
Have tried the carb/brake cleaner trick and all's good but didn't know bout the ecu trick i might give that a try oh and i put the origanal idle valve back on as it was no different with any other's !!!!
Cheer's for the tip's buddy
Offline BIGSTEVEGTI
Re: Well And Truely ****** OFF !!! PRT 2
« Reply #4 on: 02 May 2009, 12:51 »
Rite have now tried battery trick and checked go go cable and still no difference, is there a way of testing the Idle valve because if i restrict the air flow to it he idle drop's, is this a clear indicator it is bust or am i being a twit lol
Offline BIGSTEVEGTI
« Reply #5 on: 02 May 2009, 16:11 »
Rite yet another update, if i unplug the Idle Control Valve the rev's drop but dosen't cut out could this be a faulty valve ??
Offline grimmer
« Reply #6 on: 02 May 2009, 18:41 »
when i unplug my valve my car just idles rough but doesnt cut out,is this car a 8v gti by the way?
Offline BIGSTEVEGTI
« Reply #7 on: 02 May 2009, 20:25 »
16V  When i unplug it it idle's normal lol
Offline grimmer
« Reply #8 on: 03 May 2009, 21:14 »
what is the rubber seal like that the idle valve sits in?, when my 16v idled high, i found it had a 8v valve on it, the 16v is a bit bigger, also i went through 3 16v idle valves untill i found one that worked!!.
Offline Martz
« Reply #9 on: 03 May 2009, 21:26 »
Damn MK3's! :D
Solution to this problem is to get a MK2!
