Author Topic: Rotten around the fuel filler  (Read 3816 times)
Re: Rotten around the fuel filler
« Reply #10 on: 02 May 2009, 12:15 »
I dont mind if the the tank has got to come, out, as its going back to a bare shell for a rebuild.
Still think finding another shell is going to be easier
Hard to say, is anywhere rusted badly if not could be worth saving.
VeeDubGTI16v
« Reply #11 on: 02 May 2009, 13:49 »
is it the mk2 in your pic? you have to repair it, there cant be many monza blue early valvers left!
Offline Llewellyn
« Reply #12 on: 02 May 2009, 19:50 »
Fair point!
Mk2 GTI 16v
Mk2 Scirocco 8v
VeeDubGTI16v
« Reply #13 on: 02 May 2009, 20:54 »
imo the only cooler mk2 than yours is an early valver in german racing green
Offline wil0
« Reply #14 on: 03 May 2009, 02:37 »
do you have to take the fuel tank out to repair it? or can you take the pipe out instead then block off the hole?
3Door Oak Green 91 MK2 16v GTi
Offline Mr Blue
« Reply #15 on: 03 May 2009, 02:49 »
Unless the tank is empty i cant see why not or your just asking for trouble there mate. Its likely to catch fire/explode if your going to weld in that area!
A relative of mine had a car pit. The tank blew up because of a static charge that came off his clothing...with him in the pit! not worth messing around with fuel tanks, He nearly died and his garage burnt down.Scared for life.
« Last Edit: 03 May 2009, 02:52 by Mr Blue »
Offline wil0
« Reply #16 on: 03 May 2009, 04:39 »
yeah, fair. f**k getting roasted alive. il drop it out then. it should be a laugh welding it in, ive never welded before, and my mate greg says he can just about weld, so fun will ensue!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #17 on: 03 May 2009, 09:21 »
Yup. Remove the tank completely. And an empty tank is more prone to explosion than a full one. Empty tanks explode. Full ones burn savagely.
If the rest of the car is structurally sound, then I would say that a proper repair is worth the effort.
