Author Topic: hand brake light on  (Read 3154 times)
Offline Mikester
  • Civic Type R
Re: hand brake light on
« Reply #10 on: 17 June 2009, 16:20 »
the handbrake light with the abs light indicates 2 faults.
« Reply #11 on: 17 June 2009, 21:47 »
I believe the handbrake light is also linked to fluid level.
Offline Ben Lessani
« Reply #12 on: 18 June 2009, 14:11 »
Certainly is ;)
Offline B-chi
« Reply #13 on: 18 June 2009, 16:16 »
Checked my brake fluid which is on max.
It's not the abs light that stays on (it may stay on but I can't tell as the bulb has blown), it's the airbag light.
So airbag light on = handbrake light off.
Handbrake light on = airbag light off.
How do I loosen the handbrake?
It takes 1 click to apply the handbrake & only goes up to 3 clicks max. There is a slight rubbing/feint clunking from the back right. Do you think these could be connected?
Thanks for the help so far.
