Author Topic: Engine 'over revs' in 4th, 5th & 6th...  (Read 5811 times)
Offline ub7rm
Re: Engine 'over revs' in 4th, 5th & 6th...
« Reply #10 on: 28 April 2009, 20:07 »
I think they might realise things are not as normal when they get thrown into the boot  :grin:
Tough one, I think the only sensible solution is an uprated clutch  :undecided:
2020 BMW 128ti
2017 Golf GTD Estate
nige_s
« Reply #11 on: 28 April 2009, 20:08 »
Even if VW changed the clutch it would be another standard item so you'd still be in the same situation.
Offline bacillus
« Reply #12 on: 28 April 2009, 20:11 »
Indeed, a short term fix if you want to keep using the BF map.
Without traction power is nothing!
Offline Hurdy
« Reply #13 on: 28 April 2009, 20:20 »
Yup, classic clutch slip symptoms. Sach's clutch next stop!
Seat Leon Cupra Black 290 DSG
Offline Rhyso
« Reply #14 on: 28 April 2009, 20:24 »
you'd have two hopes of getting the clutch changed under warranty too  :grin: :grin:
uprated for the win :afro:
Offline chungster
« Reply #15 on: 28 April 2009, 20:52 »
clutch is classed as a wear and tear item i think, as you can abuse it with the way u drive.
if they took it off, sent it for analysis, and find that its been exposed to an increase level of torque without a shadow of a doubt, then you will have to pay for the new one and all labour costs (VW rates)
so i would just go to a reputable tuner who does a Sachs clutch kit and get it changed.
Kit is about £500, and fitting needs about 4-5 hours.
Also, if you leave it longer, you could damage the flywheel which then will be another cost to add on top!
Good luck.
Offline AlanD
  • MK5 2.0T 16v
« Reply #16 on: 28 April 2009, 20:55 »
Sounds VERY much like the clutch to me :(
Offline Russ.C
« Reply #17 on: 28 April 2009, 21:22 »
Thanks for the input all. Any recommendations on where to get in done? (Im in Lichfield nr. Birmingham). Cheers.
GTI Edition 30, 3Dr, Manual, Black Pearl, Xenons, Ipod, Highline, Rear Tints & Superchips Bluefin ;)
Offline Rhyso
« Reply #18 on: 28 April 2009, 21:25 »
Midland VW have a good reputation
they are based in Cannock
Offline Russ.C
« Reply #19 on: 28 April 2009, 22:25 »
Thanks rhyso, Ill give them a ring.
