Author Topic: Wheel spacers  (Read 2777 times)
Offline RyanManning
Wheel spacers
« on: 27 April 2009, 23:51 »
Hi
I have a 1.8 K reg mk3 and i want to get some wheel spacers to make the car look wider, But i am confused upon what to get and where to get it. can anyone help? or has anyone done this already?
Thanks
Offline VR6-Joe
Re: Wheel spacers
« Reply #1 on: 28 April 2009, 12:50 »
I've got two sets of spacers, one pair are 10mm and one pair are 5mm, got them from Hellfrauds.
Started off running with the 5mm spacers on the rear, but the rear wheels weren't out enough, so I stuck the 10mm ones on and had to modify the arches to prevent the tyres rubbing. Although my car was down about 90-100mm on 17's so that's probably why they rubbed lol.
I wouldn't really recommend those spacers though. They're fine on the back, but on the front they're useless because they're not central on the hub and therefore cause 'wheel wobble'
Your best bet is to look on ebay for Hubcentric spacers which bolt to the hub and then the wheels bolt to the spacer. They're not cheap though, so be warned :grin:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline RyanManning
Re: Wheel spacers
« Reply #2 on: 28 April 2009, 13:32 »
nice thanks for the advise mate i will have a look now :D
Offline Mikester
  • Civic Type R
Re: Wheel spacers
« Reply #3 on: 28 April 2009, 13:34 »
"Your best bet is to look on ebay for Hubcentric spacers which bolt to the hub and then the wheels bolt to the spacer. They're not cheap though, so be warned"
Hubcentric are safer.
Offline GUAVR6
  • VR6
Re: Wheel spacers
« Reply #4 on: 28 April 2009, 13:40 »
wish i could help, to bad im so far cause ive got and spare set, dood look!
SLOW VR6...
Re: Wheel spacers
« Reply #5 on: 28 April 2009, 15:25 »
the way it works is this. If the spacers you require will be enough to prevent the wheel centring on the lip on the hub, then you need hub-centric ones.  If they arent, then you dont!
There are a few variables to consider, the thickness of the spacer vs the ammount of hub lip you have is the most obvious one, next you need to check the centre bore lip on the wheels you have.  For example, 10mm non-centric spacers were fine on my TSW omegas, when fitted to my MK2 Golf.
But the same spacers and wheels didnt fit my MK1 cabby,m becasue the lip on the rear disc wasnt quite as deep as the lip on the rear disc on my MK2, that combined with the taper on the spiggot ring on the TSWs meant I couldnt centre the wheels on the cab, but they centred perfectly on the MK2.
Also, if you wnat hub-centric spacers these have to be deep enough to fit over the centre hub on the car, otherwise they wont fit flush.  For the same reason the non hubcentrics were fine on my MK2, hub centric 10mm spacers didnt fit as the centre lip was too deep, so they wouldnt fit over it.  The very same hubcentric spacers would have fitted on the cabby as the lip is more shallow, but I bloody sold them  :grin:
