The garage
Timing marks. abf
5
6
Topic: Timing marks. abf (Read 17730 times)
danny_p
Forum addict
Re: Timing marks. abf
Reply #50 on:
08 May 2009, 00:16 »
patchy signal round here.
all the VW's have gone bar 1.
sleeper16
Reply #51 on:
08 May 2009, 00:58 »
ahh right okie doke.
well thought i would leave battery off for 30mins try reset the ecu incase with the live feed shorting out it had cuased any problems but made no difference
so im now that i fixed the dizzy im getting spark with and without the hall sensor plugged in
but still not starting hmm
sleeper16
Reply #52 on:
10 May 2009, 17:24 »
i think i might try replacing the hall sender with another out of one of the 8v engines how do i strip the dizzy? i cant seem to get the steel plate off the one that spins round with the cut out for the hall senser to pick up?
danny_p
Forum addict
Reply #53 on:
10 May 2009, 21:46 »
never needed to strip on so not sure tbh normaly nick one off another engine
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #54 on:
11 May 2009, 08:40 »
think on the 8v ones you lever the plate up with a screwdriver either side, but this wont work on a 16v one you have to strip the entire dizzy down. theres a roll pin you bash out on the back end of it, then all the gubbins comes out.
sleeper16
Reply #55 on:
11 May 2009, 10:35 »
ahh right cheers jonny! i tried levering but it just bent the plate (on the 8v) i can see a pin going through the drive gear on the 8v i bet that needs knocking out, just cant figure a way of getting out.....oxy acetylene i think
not had much of a look at the 16 one yet but will get it back out n see how it goes.
danny_p
Forum addict
Reply #56 on:
11 May 2009, 16:37 »
wheabouts are you located ? if anywhere near here have a full abf worth of senders sensors and shizzel sat in a box you chould try
sleeper16
Reply #57 on:
13 May 2009, 17:12 »
sorry was away for a couple of days. newcastle. where here?
will try this hall sender swap see if it makes any diffrence might get chance over the next few days
WireZ
GTI forum regular
Reply #58 on:
12 December 2009, 20:30 »
Did you find the cause of the problem as I replaced my exhaust manifold last week and have exactly the same issue - fuel and spark but no bang. Everything look swithin spec on VAG-Com and hence is really confusing.
Shricked Bora R32 4-Motion
5
6
The garage
Timing marks. abf
