Author Topic: VR6 Rear brake conversion..  (Read 4557 times)
Offline Paul86S2
Re: VR6 Rear brake conversion..
« Reply #20 on: 27 April 2009, 19:43 »
16v Gti's don't have the rear brake bias valve, and I'm fairly certain the VR6 doesn't either, so it won't have one on the vr6 rear beam.
Paul
Offline LazyLunatic
  • MK3 20VT Project
« Reply #21 on: 28 April 2009, 00:38 »
Paul
is this really true? would make life easier, anyone have a look on there 16v and let me know cause my brakes came off a valver.
cheers.
Offline MK3TDi1996
« Reply #22 on: 29 April 2009, 08:32 »
okay - do i need the bias valve?
Offline MK3TDi1996
« Reply #23 on: 15 May 2009, 09:55 »
yes no??
Offline MK3TDi1996
« Reply #24 on: 15 May 2009, 09:57 »
i'm going to see a VR6 on sunday and i'm taking the rear brakes - exactly what bits do i need?
thanks
Offline LazyLunatic
  • MK3 20VT Project
« Reply #25 on: 15 May 2009, 21:06 »
The entire rear beam and everything attached.
abs stuff if you got that, but i didnt bother with it.
get new handbrake cables from gsf.
dont go cutting anything if you can help it, unless your going to replace it. i cut the handbrake cables, as i bought new ones (recommended). cut abs if you dnt need it. you will see what i mean when you get there and you will see the cables and piping, etc that attaches the car to the beam.
the rear beam is held on to the brackets via rear beam bushes and a bolt. you want to keep the beam and bracket attached, and remove both as one piece. i think there is 3 bolts holding the each bracket to the car, one bracket each side. make sure you detach all the brake lines, cables, etc before undoing the bolt.
LL ;)
