Author Topic: Headlamp washers??  (Read 2499 times)
Offline mikemk4gti
Headlamp washers??
« on: 21 April 2009, 21:10 »
 Well, Had the golf 3 weeks ish now and noticed it has covers on the bumper under the headlights. the previous owner said they were just covers. After having the car on a ramp today I found a pipe blanked off in the n/s front bumper and had a look and saw it was from the headlight washer so I reconnected it and it started leaking - turns out the washer on that side is cracked  :sad: anyway, the o/s one is still connected so why doesn't it work? I have checked the fuse and its ok, Where is the pump so I can check if its getting power? and anyone know a cheap place to get a replacement washer thingy for the n/s?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Rhyso
Re: Headlamp washers??
« Reply #1 on: 21 April 2009, 21:11 »
pump is located on the front of the windscreen washer bottle and simply pushes into the bottle
think a new one is about £40 or more mind!
Offline mikemk4gti
« Reply #2 on: 21 April 2009, 21:15 »
is it different pump for the windscreen washers? how exactly do the headlamp washers operate? I have tried ign on headlamps on and operating screenwash.
Offline Rhyso
« Reply #3 on: 21 April 2009, 21:17 »
yes two seperate pumps - one at the back for the windscreen and the other at the front for the headligh washers
not sure how they operate as i don't have them but i think they work every 1 in 5 washes of the screen  :undecided:
Offline mikemk4gti
« Reply #4 on: 21 April 2009, 21:19 »
ok, think I know which pump it is then
Offline bobbarley
  • I'm kind of a big deal...
« Reply #5 on: 21 April 2009, 21:21 »
The headlight washer jets only activate when you have your lights switched on.  If that helps?
Offline mikemk4gti
« Reply #6 on: 21 April 2009, 21:22 »
yeah tried that, think i'll connect a test lamp to the plug on the pump and see what happens.
Offline Steve_PD
« Reply #7 on: 21 April 2009, 21:24 »
Its meant to be 1 in 5 but mine has mind of their own, sometimes they go everytime, sometimes 1 in 10. I think the outside temperature has something to do with it as well. and you dont want them to work if you like your car to be clean  :wink:
Offline bobbarley
« Reply #8 on: 21 April 2009, 21:25 »
Mine spray the lights every time  :huh:
Offline Steve_PD
« Reply #9 on: 21 April 2009, 21:26 »
It does say in the handbook 1 in 5, but in winter it was every time, now it hardly does it on mine  :undecided:
