Author Topic: Design 90's  (Read 804 times)
Offline fazzybear
Design 90's
« on: 21 April 2009, 19:22 »
Anyone running design 90's on their mk2/rallye, im haveing trouble deciding what size adaptors to get
fronts are 8" et 52
rears are 9" et 52
could you post pics if you have some please
Offline maplesyrup
Re: Design 90's
« Reply #1 on: 21 April 2009, 22:12 »
Hello, I ran 8" d90's with a 52mm offset on the rear of my golf with 20mm spacers and got a little rub on the inside edge, they sat very close to the swing arm, so I bought 25mm spacers and they were spot on.
With 9" rims you may need to run wider adapters to get the clearence, if the offset is the same - I guess you may have more arch space though if you have the Rallye arches so wider spacers may be ok?
8" on the front should be fine with 25mm spacers.
 :smiley:
"when the going gets weird the weird turn pro"
Offline fazzybear
Re: Design 90's
« Reply #2 on: 22 April 2009, 08:14 »
Cheers dude, its complicated trying to get the stance spot on
ive been told that others use so many different sizes i need to test some really
Offline Diamond Hell
  • Opinions я Us
Re: Design 90's
« Reply #3 on: 22 April 2009, 10:06 »
If it's a Rallye I would advise you to keep same width rims and tyre size all round, or you're likely to tear the drivetrain to pieces and never mind the ghey 'stance'.
Offline Organisys
  • Old and Slow...
Re: Design 90's
« Reply #4 on: 22 April 2009, 13:21 »
fronts are 8" et 52
rears are 9" et 52
Call Darren at G-Werks, he will sort you some adapters.
