Author Topic: Sunroof problems :(  (Read 817 times)
Offline jim182
Sunroof problems :(
« on: 21 April 2009, 17:46 »
Just took my sunroof out and fitted a new headlining to it as my old one was ripped and hanging down.. i've put it back in but when i go to close the sunroof it closes normaly till there is about an inch gap left then it just stops as if it is wound fully closed:S what could be causing this??
cheers
jim
www.myspace.com/deadcannons
Previouse Dubs - Mk2 1.3, Mk3 1.4 SE, Mk2 1.6 Gti Replica - Currant boring company Audi A3 & Type 19 1.6 Driver
Offline Ben Lessani
Re: Sunroof problems :(
« Reply #1 on: 21 April 2009, 18:02 »
Poor adjustment, just undo the 4x bolts holding it in and square it up, its pretty straightforward.
« Reply #2 on: 22 April 2009, 09:32 »
sounds like handle isnt fitted right, the stop is builkt into the handle gear mech :)
take handle off, wind it back a few turns then refit and try again. keep going till roof fully shut, then remove handle 1 last time and wind it till it hits the stop, refit :)
