Author Topic: Guide to removing / bypassing the N249 valve.  (Read 100949 times)
Offline golfgar
  • Audi A6 estate/subaru wagon
Re: Guide to removing / bypassing the N249 valve.
« Reply #10 on: 23 May 2009, 21:49 »
top guide mate,didnt take long :grin:
Offline GregUK
  • 2001 Golf GTI 1.8T AUM 150bhp in Diamond Black
« Reply #11 on: 25 May 2009, 22:36 »
so it just makes the throttle a bit more responsive? and risk of anything exploding..?
AFAIK, the AGU/ARZ doesn't have have the N249 valve, so this mod just makes the AUM/AUQ function in the same way.
Offline navmk4gti
« Reply #12 on: 10 June 2009, 02:27 »
can i ask why bypass the valve?? what you get out of it  :lipsrsealed: sorry dumb question :embarassed:
Offline GregUK
« Reply #13 on: 10 June 2009, 10:47 »
The valve allows the ECU to open the DV at any time rather than allowing it to open habitually.
Bypassing the valve makes the DV more responsive, and the boost curve more smooth and progressive.
Offline navmk4gti
« Reply #14 on: 10 June 2009, 12:55 »
kool  :smiley:
but arent there any side effects after doing this..future problems???
Offline GregUK
« Reply #15 on: 10 June 2009, 13:00 »
It's clearly been put there for a reason, but the fact that the earlier Mk4s did without the valve is reason enough for me to bypass it!
I've not experienced, or read of anyone else having problems as a result.
Offline navmk4gti
« Reply #16 on: 10 June 2009, 14:40 »
iv got a AGU 98 mk4 will mine have it den?? iv got a forge splitter d/v with no probs
Offline barry-gti
« Reply #17 on: 10 June 2009, 14:43 »
i think its the ARZ's that dont have one??
Offline GregUK
« Reply #18 on: 10 June 2009, 14:47 »
I'm not sure which engine codes have them, but if you've got the N249, you will also have a vacuum reservoir covering your 4th coil pack/spark plug.
Offline navmk4gti
« Reply #19 on: 10 June 2009, 14:59 »
ill check it out and let you guys know..  :smiley:
