Author Topic: This is going to be bad isn't it.........  (Read 1736 times)
Offline Ben Lessani
Re: This is going to be bad isn't it.........
« Reply #10 on: 17 April 2009, 10:20 »
If its your big end bearings, then if you change your oil - it will have white metallic flakes in it.
If its the exhaust - then holding a piece of tissue next to the downpipe will show you if its blowing or not.
Just listen to where the noise is exactly coming from.
Offline 16valve
« Reply #11 on: 18 April 2009, 23:25 »
Tapping or clattering??? And is it defo linked to gear mishap or was it maybe making a noise before hand??
Sounds silly but maybe check oil level as in previous post??
Has it had an easy life history low miles etc ..
