Author Topic: Idle to high (changed maf)  (Read 2753 times)
Offline richw911
Re: Idle to high (changed maf)
« Reply #10 on: 16 April 2009, 19:04 »
I did the throttle body clean last week as a measure of trying to eliminate the problems. The ignition shouldnt affect the boost should it ?
It will cause the idle problem and will affect the vacuum on your gauge.
Offline richw911
« Reply #11 on: 16 April 2009, 19:05 »
Just been told that the actuator on the golf is onlymade to boost to 1 bar and if exceeded for a long time can break
This correct ?
Not sure about that claim - could be the fault tho  :undecided:
Offline Voodoo-Music
« Reply #12 on: 17 April 2009, 14:51 »
Got a new issue now. When i pull up anywhere the car will idle at 800rpm then gradually gets higher till it hits 1200rpm
This is so unusual
